Livernois Motorsports Tune 2025 Ford Explorer ST 3.0L!
Wellington, FL, USA
Good Morning, #teamlethal fans!
Livernois has just announced and released their newest project for your ST!
Here's some of the highlights:
Purchase of this tuner includes 1 gasoline tow tune and 1 gasoline performance tune for a stock vehicle. Extra tunes can be purchased under the optional add-ons drop down.
Features:
Custom tuning via Livernois Motorsports
Increased horsepower & torque (+110hp/115tq w/ 93 Octane R+M/2 fuel)
Dyno proven fuel/spark/boost adjustments
Multiple tunes for Performance and Towing
Enhanced throttle response
Modified Fan Settings for reduced heat soak
Revised Start/Stop control logic
Transmission Shifting improvements
Removal of skip-gear function
Reduced Torque Management and increased Shift Firmness
Available for multiple fuel octane levels (87-93 Gasoline, with optional E30 and higher currently available)
Raised top speed limiter
Ability to Read/Clear (DTC) Codes
*Windows PC required for tuner updates, MAC / Apple OS not supported*
Ready to grab one? Check it out here --> Livernois Motorsports MYCALIBRATOR Touch Tuner (2025+ FORD EXPLORER ST 3.0L) - LPP631191
new york
2025 st
will be interesting to see youtube clips after this is installed of real world results
Lljes1
Chicago IL
'25 ST
This is GREAT news! When I was first looking at the '25, I saw the For Performance branded version and started doing research, had the dealer put as an IOU on the purchase only to find out my '25 wasn't supported.
JakeLethal
Wellington, FL, USA
Morning, Everyone! Here's some results for you all!
G8gt594
Flordia
So we buy the calibrator and we get 2 canned tunes, is that correct?
No 2 custom tunes.
What Livernois calls custom tunes, we consider canned tunes. For the $699, you get the device and a tow tune and a performance tune. I could be wrong but there is no data-logging for these tunes but you can specify certain features like softer shifting if it is too harsh for you.
Really? That is interesting, thought they were custom tunes.
Fort Lauderdale, FL, USA
Hey Jake - website had mentioned gains of over 100hp & 100tq. The dyno numbers you mentioned, didn’t quite showcase that. Is there something else needed to get those higher shown numbers (ethanol) or has there been an update internally that allowed higher yields?
South Florida
2012 CTS-V, 2021 F-150 Ecoboost
Hey there!
We grabbed these numbers directly from Livernois, and per their video, they take the "peak v.s. peak" to redline on the dyno results for 87 and 93 octane. Below is a screenshot that better showcases what exactly they mean. I will admit, it is a little weird to display it like that, based on how others have displayed their dyno results, but at redline, it shows that 100whp/wtq difference.
They also have some dyno footage of an Aviator with a 3.0T putting down over 100hp/tq difference on just their tuning, both in midrange peak and redline peak. They've dyno'd and tested a ton of different Explorer ST's and Aviator's, so will results vary with each dyno day, conditions, vehicle, mods, etc.
Hope this helps !
