2025 no mods w/ ZFG 93 tune
Suprawill1
What? It’s about $950 for the tune, intercooler is around $800, exhaust is $1800, DPs are like $600.
ZFG DMS 93 tune cost me $1150. That's with the OBDII tuning device added. Intercooler is around $800 but will jump up to $1400 plus, if you get it installed.
And yes, the DPs are $600.
Ok, but that’s not near as much as the other guy was talking about, and I wasn’t referring to install as that is always super objective depending on where your located and different mechanics. But yeah, you’re not wrong either.
Suprawill1
True dat. It's all good.
Papillion, NE
I have the exact same 93 ZFG tune on a stock 2023 ST. I have the DMS tune tho but I basically keep it in Sport mode. My dragy numbers are slightly better than yours but I haven’t done a full 1/4 yet. My DA was a lot better congrats brother! I’d like to hit up a dyno and see if I can possibly tweak it some more. Maybe do an E50 tune.
CessnaDriver
Active Duty U.S. Air Force
Bossier City, LA 7111
Wow thanks for posting that, I recently got a ZFG tune for my 2020 stock explorer. Haven't tested it yet, but I didn't realize it made that much of a difference in 0-60. I was only expecting something like a 5 seconds flat, I didn't expect it to get into the low 4s.
Suprawill1
Depending on the ZFG tune and engine conditions, the tune can provide up to 100 AWHP.
#27
From my reading, assume Race=approx 100, Performance=80, DD=60 and Tow=40. Oversimplifying, but it gives you an idea, where each one falls from Race. I feel like his percentages for the modes are 100% race, 90%, 60% and 40% as you reduce the tune. Once again, oversimplification from reading his site and posts.
SoCal
#28
I already have an Accessport, but I am tired of waiting for Cobb to crack the 25's. So I went to ZFG's website and spent 45 minutes researching and putting together a package of hardware plus tune, only to find out in the final checkout that they won't ship to California. Guess I'll just wait and let Cobb have my money. [?|]
DANIMAL402
Papillion, NE
I recently cut a 3.92 0-60 in very cold weather and the 60 ft was only a 1.80
#30
I'm finding the RSB and the 93 Tune make this car a different animal altogether. Fun to drive, and the power will surprise you.
#31
I love it when I let people drive my ST and see their expression when I switch it from Normal (Performance+) to Sport (Race). There is a significant difference!
Suprawill1
Big time! Even before and after the bolt-ons, the difference is remarkable.
Dr.Cheeseburger
Thread Starter #33
Finally got some better temps and some better air. Still 100% stock vehicle except for my ZFG 93 tune. Stock exhaust, stock air box, stock intercooler, 100% 93 octane gas (E10). Next time I'm going to mix a tank of E30 and see what she does.
4.12
12.53@106
Side note....love my ZFG tune. Can't say enough about how great this thing drives now. MPG is down a little obviously but I also drive it pretty hard. Got a P3 installed so I can actually see some real temperatures on everything. Both have been great purchases. Highly recommend.
#34
I assume that's Sport mode? I mean, in full send, she still goes in Normal.
I've found my range for my driving is about 390-400 if I run Normal all of the time. If I use Sport its about 360-370, mixed stop and go and hwy.
Dr.Cheeseburger
Thread Starter #35
Yes all of these runs are in sport mode. I just love how it shifts now so I run in sport mode a lot of the time.
Not kidding I usually fill up and it says 390-400 miles to empty if I run normal all of the time. Thats funny!
#36
I've adapted to Normal, but Sport is def more fun.
Dr.Cheeseburger
Thread Starter #37
Still bone stock (only ZFG tuned). Full weight. 3/4 tank full of approximately E30 by me putting 5 gallons of E85 in the tank and then filling it the rest of the way with 93. I didn't actually measure the percent so who knows.
4.07
12.43@107
moto727
Jacksonville, Fl
4.07
12.43@107
You’re probably around e 35. Usually it takes me about 5 gallons of the corn to hit that. Also, here the calculator that I use. https://www.tuneplusinc.com/pages/tuning-tools
Suprawill1
4.07
12.43@107
It also depends on the e-pump. It's no longer a guaranteed 85%. I've tested as low as 70% but some pumps around here quote 52-83% ethanol.
For everyday driving, it's an inconvenience to have to test the fuel every time you need a certain percentage of ethanol. That's why I went with a FBO setup.
E85 can still enhance power if I need it. In the meantime, I'm happy to see you get good numbers on tune alone.
Fort Lauderdale, FL, USA
4.07
12.43@107
Is your ST AWD or RWD?
Which drive mode did you get? Seems like it’s a 93 octane tune, but did you do Race, Performance, or Daily Driver mode?
