Doors Woofers Upgrade
zorronj
NJ
FORD EXPLORER PLATINUM 2020
Explorer 2020 Platinum with 14 speakers B&O system
I have 2 pairs of Dynaudio Esotar 2 650 6.5 woofers with 93 sensitivity and planing to replace the stock doors B&O with them to get a better sound quality
Do you think the B&O amp will handle it as the Dynaudio's are 200 watts each and 04 ohms, also how many watts each of the B&O system doors channels amp have it?
Any comments will be appreciate it
Stock power is low. Get the best high sensitivity drivers you can find.
What you’re describing is a recipe for disappointment. And why in the world would you want to waste drivers of that quality like that anyway?
Z
zorronj
NJ
I have the drivers removed from my old Explorer and want to keep them
Z
zorronj
NJ
Sorry I forgot to mention, the Dynaudio's sensitivity is 93
Toronto, Ontario, Canada
I have the exact same speakers in my rear set up & Esotec MW 172 in the fronts. To get the best bang for your buck you need sound deadening in the doors & door skins. Then a good dsp & amplifier. Just swapping out the speakers you will not notice much difference. If you can afford to do only 1 thing then sound deadening the doors first is a must. I don't care how good a dsp & tune & amplifier you have. If you have all kinds of rattling in the doors it defeats the purpose. Sound deadeng first is a must. Just opinion though.
Z
zorronj
NJ
I know that, I just checked 2 days ago with Crutchfireld and they told me the Explorer Platinum or ST B&O 14 speakers, the factory amp have no more than 15 watts on each door speakers, unbelievable for what they call Premium sound system .
I'm thinking about buy a Dynaudio X 362 3 way crossover, plus 2 Dynaudio midranges and 2 tweeters to use at front with the Esotar 650 and for the back I'm gonna use a pair of Esotec plus 2 tweeters and X252 crossover that I have it
About the amp and dsp I don't know which model or brand to buy. Any suggestions ???
For a dsp I have a Helix dsp pro mk2 . For amps I have a zapco 150.6 which is a 6 channel amp & a zapco 400.2 2 channel & I have a Sundown Audio Salt4 for my subs. But I did have a zapco Z-3Kd ii but blew that. Great dsp & amps in my opinion. Money will be your deciding factor in the end.
Z
zorronj
NJ
Your Zapco 150.6 its the AP version and how do you have connected on your system? Bridged??
Yes both Zapco amps are the ap version. I have them connected through the Nav Tv ZEN AUDIO DSP12A-A2B KIT. Uts a little pricey but you keep everything oem & no splicing any wires.
Z
zorronj
NJ
About the Dynaudio speakers do you have them connected in 2 or 4 ohms?
Z
zorronj
NJ
Thread Starter #13
Also where do you have it the amp installed in your Explorer because this guy it's 24 inches length ?
Here's a pic of my trunk. Not the greatest but everything fits.
Z
zorronj
NJ
Thread Starter #15
In case you will need to remove the spare tire how can you do?
I just pop out the right side lower panel & I have a handle installed on the side & then I just lift it up. No wires hanging or nothing. Everything in mounted to the amp rack in which all 3 amps sit on.
Z
zorronj
NJ
Thread Starter #17
When you have a chance can you please send me more detailed pictures including wires,RCA and speakers cables brand,the handle location and also how do you get the amps placed have you used things like velcro, about the base have you cut a plywood and covered? Sorry about to many questions but I need it to know and show to my installer
I really like the way you did it your set up
I’m gonna do mine full active system front and rear, I have the Zapco 150.4 AP for rear 2 way now I’m looking to buy a 150.6 AP for front 3 way, sub amp maybe A/B class also, the subwoofer I have a couple suggestions like Morel Ultimo 12” to install in the factory enclosure, I got Helix DSP Pro MK2, PAC FD31
Thank you so much, your help will be appreciated
Reinaldo
