Leak from driver side rear?
LADMarines
Active Duty U.S. Marine
Twentynine Palms, CA
2020 Explorer St
Has anyone had any water leaking in the rear by the back speakers? It hardly ever rains in the desert but the past few months it has and we'll I have a leak. Before I send it to the dealership anyone had this happen? I might try to pop off panels and see where it is coming from too.
Sent from my SM-S908U using Tapatalk
With the liftgate open, make sure the rubber boots are all intact or that could be a source for water intrusion. The roof drains go down the c-pillar so that wouldn't make sense.
Scott Rich
Sicklerville, NJ
Have the same issue on my 22....drains are clear and flowing. Someone on Facebook said they had a rear side window leak....the rear windows have built in seals and are pressed into the body at the factory. It could be bad seals or missing seals. If it is the case, the entire window needs to be replaced. Dealer will check for 200 bucks and if out of 3/36 warranty, you may be on the hook for entire cost. Extended warranty may not cover it.
