Parking sensors yelling at me...
BIMGuy
Jax, FL
2020 Explorer Platinum
For the past few days my Explorer has been yelling at me when I turn the wheel hard to park in my driveway. The first time I thought it was just being overly cautious with my trashcan on the street (it was 5'+ away from the car though), but now it has been doing everyday when there is absolutely nothing within 15' of the car when I turn into the driveway.
Periodically, the sensors make a brief amount of noise for no reason while in city traffic situations, so maybe the system is starting to breakdown.
Anyone else ever experience this, and have an idea on the fix?
Thanks,
Zac
Is your driveway at an angle?
Is it the same sensor alarming every time or is the whole system too sensitive? In any case, if I get a system out of wack, sometimes a good reboot will cure it. Sometimes even a Forscan module reboot doesn't work so I would recommend disconnecting the battery for 15 minutes.
B
BIMGuy
Jax, FL
Yes the driveway has a slope to it, but this is a Florida home so not much slope ;)
B
BIMGuy
Jax, FL
It seems to be a couple sensors on the passenger side each time. I will try the battery disconnect over the weekend and hopefully it help. My front right tire pressure sensor is showing a fault as well, so maybe that can be magically fixed at the same time.
I was gonna say, because mine go off every once in a while pulling into my driveway.
2020's are needing all the TPMS sensors replaced. They only last 5 years... Do them all at once, preferrably when you need your tires replaced.
Suprawill1
That's good to know because 3 of mine have gone out in the last month. I was going to do a TPMS reset to see if that was the problem but upon seeing your post, I'll probably just buy new ones.
Rockford, IL, USA
i just experienced the same issue, looks like one of my sensors has fallen into the bumper
B
BIMGuy
Jax, FL
I am doing the battery disconnect now, and will report back later with my findings, but I was wondering if any of you purchased the extended warranty from Ford and if the TPMS and parking collision sensors would be covered?
I believe so.
B
BIMGuy
Jax, FL
Well it did nothing for the TPMS, and in fact I now have TWO faulty sensors, and the parking sensors still beep at me when I pull into my driveway but not nearly as bad as they did before the battery disconnect.
As a point of reference....I had the battery disconnected for at least two hours, so hopefully that gave the system plenty of time to reset itself. I was surprised to find that my radio station presets were still there, so maybe it could have used more time to completely reset itself????
