Audio Control LC2i vs LC2i Pro
I have read through some posts on here and can't seem to find a solid answer. I am currently using a LC2i to provide signal to my sub amp. At high volumes the output is throttled because the signal going to the factory sub is reduced. Some say the LC2i Pro fixes this issue. Is this correct? Does someone have actual experience with it? Thanks
Home
2025 Explorer ST AWD
@UNBROKEN Has extensive knowledge as to the aftermarket stereo, maybe he can answer
If you are playing your stock system in the useable volume range, you should not see bass attenuation.
B
Well my stock system is useable to about 80% volume. That is roughly 26 out of 30. The bass is restricted at any level higher than 15.
