SLD Steeda Explorer Rear Diff/Pinion Bushing Kit (2020-2025) For Sale
dholl
Nj
2023 explorer
Steeda’s ‘20+ Explorer Diff/Pinion Bushings in great condition.
Made with high quality, domestically poured urethane, billet aluminum sleeves and steel washer. These add strength and durability to your factory rear bushings.
According to Steeda, these bushings add zero NVH while also being 30% stiffer than the factory bushings.
Simple, reversable install means no permanent modifications!
$130 shipped from Butler NJ by USPS.
Contact me at [email protected] or PM me here.
Thanks. Dave
Charlotte
2021 Ford Explorer ST
Why’d you remove them?
D
dholl
Nj
2023 explorer
I was having some increased NVH and had seen some stories of the bushing failing (tearing) and I eas just uncomfortable with them installed. So I went back to the stock part for piece of mind.
Charlotte
Funny how some people experience that issue and some don’t. I think it’s possible that when this occurs either they were installed improperly OR the drivetrain is finding another weak point, like a bad bearing, which isn’t revealed with the stock bushings. I guess we can’t know everything. Thank you for your honesty. Someone could buy them from you and still potentially not have that issue I guess.
I’m about to install the JXB diff insert and hoping it does not cause any NVH, I was also thinking that if I stiffened that up then it may be necessary to get the pinion bushings too. But I’m wary. I’d prefer not to pay hundreds for parts and labor for something that isn’t necessary or highly recommended.
