Water Leak - Passenger Front Right
Evansville, IN, USA
This started about 2 weeks ago. When we have heavy rain there is water in the all weather floor mats. The water is dripping in from behind the glove box on the right side. Any suggestions on where to start looking would be appreciated.
Thanks!
Check the plastic cowl seal where it butts up to the windshield over the top of the battery.
Baldwin Harbor, NY, USA
About the same time for me as well. 2020 ST. The cowl seal at the bottom of the windshield has popped out on the right side. Now to try and get it back in. Not sure it would be covered by Premium Care extended warranty.
MD
Yea had that happen to me, but pushed it back and been good every since
T
Evansville, IN, USA
Its been HAF recently but I pushed down on the cowl and it "snapped" into place. I assume this originated from me replacing the battery. Fingers crossed.
Wow! The middle of the right side piece was completely out. I snapped that in, then kept on pushing toward the right A pillar. I did have the battery replaced over two years ago so I'm surprised it took this long if that's when it wasn't originally popped in as it should be. Time will tell. Thanks all.
