2025 Active Shutter Error Code - Fix?
East Coast
This may not be the best section for this post but it's related to my CVFab intercooler installation - Admin, please move if necessary.
I thought I would make a separate post for this topic as I have seen it pop up sporadically in a few build threads. I recently installed the CVFab intercooler and removed the active shutters, leaving the assembly and the motor, and am now constantly getting a "shutter travel min/max" error code. Based on research it seems like some folks who do this don't get a code and some DO get a code...both scenarios seem to be installing/handling the shutters the same way. I know @skylercolwell is experiencing the same and is looking into the As Built information. I emailed Cobb the other day, relaying the problem, and asked once they crack the ECU code, to consider making this an enable/disable function for us - I have not gotten a response.
Any others experiencing the same issue and/or discovered a solution?
AMCfoxbody
East Coast
I heard back from Cobb today:
That is something we've done with the Raptors/F150's on our Stage 2 OTS maps so once we're into the '25's and hopefully make a Stage 2 map that uses an intercooler it would hopefully be the same thing!”
AMCfoxbody
East Coast
Anyone had any luck with this? I’m still fighting the CEL. I would really rather not have to re-install all of the shutters just to clear the CEL long enough to pass inspection.
New Albany, In.
2025, Explorer ST
Are you getting this because you installed the intercooler and left the shutters in place—just unplugging them for the install and then reconnecting them—or did you completely remove the shutters from the assembly? Asking because I have a 25 and just bought the intercooler, but haven't installed it yet
Illinois
I think the issue is because the shutters were removed. I installed the CV Fab FMIC and charge pipes on my 2025 and did not have any issues with CEL's disconnecting and reconnecting the connectors.
AMCfoxbody
East Coast
Correct. The issue was removal of the shutters after CV Fab FMIC instal. Some seem to have no issues with the CEL and other lucky ones have the CEL…
I just don’t see any point to removing the shutters.
st charles il
You can remove most of the shutters but have to leave three of them in to get past this code we spent hours on finding the problem on one that we did on the older models you can remove them with out issues but 25 and newer you can’t just remove all of them
AMCfoxbody
East Coast
Thanks for the reply! So... just adding any three back in will 'trick' the ECU into turning the code off? Did it matter which three you put back on?
st charles il
No you have to add the main or middle one in and the the top and bottom ones
AMCfoxbody
East Coast
Perfect, thank you again!
Combatvet
What great information, I hope this clears your fault codes.
