Is there a problem with electricity? It's the 2nd one
대한민국
2023 링컨 에비에이터
Drive, stop the car, keep the door closed and make a warning sound
When you close the door with the remote control, you hear a warning sound, and when you press the power button after boarding, you hear both electrical and electronic sounds and there was no response
And after 10 minutes, the engine started normally and the monitor turned off. Why is this doing this? The battery is normal
Could be a hundred different things. Got any videos of it?
Desert South West
Have you checked for Diagnostic Trouble Codes ?
