Files for Fullscreen Mod
New York
2024 Ford Explorer ST
Hi all,
Wondering if someone had the 3 zips needed to perform this mod. I tried getting it from fmods but figure out which ones are the ones i need. Any help is appreciated. Thanks
Bocker
Toronto
2023 Stone Blue
C
New York
Thank you. So each of the first 3 on a separate USB and the 4th on a different USB too?
Bocker
Toronto
2023 Stone Blue
Yes, make sure the syncmyride folder is in the root of the usb drive.
Jail break is the hardest one (usb1). You have to reboot at just the right time. If USB2 results in error message, redo USB1. It took me multiple tries... some people succeeded after 1 or 2 tries.
Toronto, Ontario, Canada
do I need to back anything up in forscan? or if it fails to not jailbreak it does it just revert back to oem? thank you. Also so the only thingI need is 4 usb sticks right?
US
Ford
Well took about 4 tries to get the timing down for the jailbreak. But super easy after that.
What a great mod!
Sent from my SM-T307U using Tapatalk
Dallas, TX
Correct, you just need some USB storage. Using 4 just makes it easier to do. Also make sure you Sync3 is updated to the latest version. It's been out for a while but there are plenty of people who still haven't updated. This mod will not work if you're not on the latest version.
LADMarines
Active Duty U.S. Marine
Twentynine Palms, CA
2020 Explorer St
I am having issues with drive 4. Should I put all the files that I unzip in the root of the drive? It says it is starting software, but then it does nothing. I sat for 10 minutes, and nothing started. Screenshot 2025-05-08 183113.jpg
Dallas, TX
Open the README file with notepad, there should be some instructions there. I haven't downloaded or installed this yet so I'm not sure exactly.
Thank you. Going to give this a go very soon.
