Fullscreen question
RusW1
Missouri
Hi everyone,
I'm a little late to the game and have a quick question. Does the fullscreen jailbreak or any FORSCAN setting allow the back up camera to to be viewed in fullscreen mode? I'm considering the mod but want to manage my own expectations before attempting. Thanks in advance for replies.
No. Camera views are unaffected. Really only affects Carplay or Android Auto. Don't use those? Then no benefit.
sparkn
2022 Ford Explorer King Ranch
I doubt the fullscreen jailbreak will ever be able to do this. The camera is available while Sync is still loading. The binaries for AA/AC were the only things changed for the MOD that I've read so far.
I think the only thing that gets you a bigger camera view is the Aviator screen and even then it’s only marginally larger.
RusW1
RusW1
Missouri
Thanks guys,
Saved me from the expense and disappointment managing expectations. Now on to new wheels and tires.
Dallas, TX
Thanks guys,
Not really much expense other than the thumb drives to load the software. Personally I think it's a huge improvement over the stock layout. I can't say it's any more or less laggy than it was before the mod, I've never liked Sync3 or the touch screen compared to the Uconnect8 I had in my Charger.
Orwigsburg, PA
If you have some old 1gb or less flash drives sitting in a drawer, put them to good use by doing the full screen upgrade.
RusW1
RusW1
Missouri
Yeah,
I had a couple of Durango Hellcats and the Uconnect was great.
RusW1
RusW1
Missouri
Is it fairly easy and straight forward?
Dallas, TX
Hardest part is getting the timing right when doing a reset of the infotainment and inserting the jailbreak USB.
thinguy
United States
2011 edge
4 cheap USB drives, 30 minutes to do the upgrade, and patience to get the timing right. 100% worth it unless you don't use CarPlay or Android Auto. Makes the screen look like it should have from the factory.
Chamorro85
Illinois, USA
Couple videos on youtube that show it's pretty straight forward. Jailbreaking is hardest part like others have mentioned. Could probably get it first or second try now that i've done it. Love the display so much more now and save money from conversion to Lincoln screen.
